tkmbe avatar image
tkmbe asked
Terminals connections screw does not ajust anmyore clamper. How to solve?
Hello
On my SmartSolar MPPT 75/10 on of the screw has left the position to adjust the bottom plate from terminals connections. I'm not able to get again to adjust. Anyone know to solve the problem?
charger
Paul B avatar image Paul B commented ·
I do not understand your issue, Maybe some photos Please
tkmbe avatar image
tkmbe answered ·
The marked terminal does not pressure the cable inserted. The screw does not move up the plate.
I have opened to big and the plate is not anymore connected to move up and down with screw.
mrhappy avatar image
mrhappy answered ·
If the threads on the screw stripped, take the screw out and try to find one with the same thread. If the threads in the terminal stripped, then maybe it is possible to gently thread the hole to one size larger threads and try with a new matching screw.
