bigstig avatar image
bigstig asked
Victronconnect stalls update at random percentage
After multiple attempts to install the 1.56 update. VC gives D26 Connection lost error. The 150/85 shows no version and doesn't work at all just flashes the tx/rx light sequence constantly. Install starts pauses at 3% at 4% the victron unit stop flashing and holds a solid green led. The the tx/rx sequence flashing starts again and the transfer data percentage rises. It has got as high as 75% though usually fails near 22%.
I ordered a ve direct cable but it didn't come with a USB end, just two "jst ph 2" ends. I'm frustrated. Any ideas on how to get it to update and start working again?
firmware update
Did you try to use another smartphone?
You odered the wrong cable:
https://www.victronenergy.com/accessories/ve-direct-to-usb-interface
Create a service report after a failed update and attach it to you question.
https://www.victronenergy.com/media/pg/VictronConnect_Manual/en/troubleshooting.html#UUID-98bc9211-902b-01a0-96b9-1f314c4d63c5
