waffleking avatar image
waffleking asked
Venus OS 2.73 Raspberry pi 4 WiFi not working
I have a Raspberry Pi 4 running Venus OS v2.73. It has been working fine for a few days and this afternoon VRM stoped getting updates. So I checked the local remote console. No response. Reboot doesn't fix it.
From VictronConnect > Setting > Network settings I can see my wireless AP. I attempt to connect. After attempting to connect it says "Connecting to <WIFI> failed. Could not connect to the network."
I have many other devices connected to the same access point so I don't believe that is the issue.
I can see wlan0 when doing an 'ip addr'
# ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group defaul                      t qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,DYNAMIC,UP,LOWER_UP> mtu 1450 qdisc mq state UP gr                      oup default qlen 1000
    link/ether dc:a6:32:af:57:48 brd ff:ff:ff:ff:ff:ff
    inet 192.168.1.182/24 brd 192.168.1.255 scope global eth0
    inet6 fe80::dea6:32ff:feaf:5748/64 scope link
3: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,DYNAMIC,UP> mtu 1450 qdisc pfifo_fast                       state DOWN group default qlen 1000
    link/ether dc:a6:32:af:57:49 brd ff:ff:ff:ff:ff:ff
4: ll-eth0@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1450 qdisc noqueue state                       UP group default qlen 1000
    link/ether ee:6c:f9:54:c4:ef brd ff:ff:ff:ff:ff:ff
    inet 169.254.12.22/16 scope link ll-eth0
    inet6 fe80::ec6c:f9ff:fe54:c4ef/64 scope link
I attempted a fix from another thread with no lock (the Error only shows via ssh not when directly connected to device.
# connmanctl
Error getting VPN connections: The name net.connman.vpn was not provided by any connmanctl> enable wifi
Error wifi: Already enabled
connmanct
Wired Ethernet works fine.
Interesting VictronConnect show Link-Local Address from ll-eth0, which is neither the wired or wireless connection, and doesn't show in /etc/network/interfaces
Here is the /var/log/messages output from connecting to VinctronConnect and attempting to connect to WiFi:
Sep 18 17:27:05 raspberrypi4 daemon.warn bluetoothd[582]: No cache for 3C:28:6D:31:F4:8B
Sep 18 17:27:07 raspberrypi4 daemon.warn wpa_supplicant[736]: wlan0: Failed to initiate sched scan
Sep 18 17:27:27 raspberrypi4 daemon.warn connmand[659]: Skipping disconnect of 535057694669_managed_psk, network is connecting.
Sep 18 17:27:30 raspberrypi4 daemon.notice wpa_supplicant[736]: wlan0: Trying to associate with SSID 'SPWiFi'
Sep 18 17:27:30 raspberrypi4 daemon.info connmand[659]: ntp: time slew -0.006479 s
Sep 18 17:27:33 raspberrypi4 daemon.notice wpa_supplicant[736]: wlan0: CTRL-EVENT-ASSOC-REJECT bssid=00:00:00:00:00:00 status_code=16
Sep 18 17:27:33 raspberrypi4 daemon.info connmand[659]: ntp: time slew -0.004943
Venus OSwifi
waffleking answered ·
While this is still broken using the VinctronConnect App, I was able to get connected using connmanctl. Before I did this I removed the wifi_* directorires in /data/var/lib/connman/wifi_*
$ connmanctl
Enabled Wifi
connmanctl> scan wifi
Scan completed for wifi
connmanctl> services
    MyWiFi         wifi_1234
connmanctl> agent on
Agent registered
connmanctl> connect wifi_1234
Agent RequestInpu wifi_1234
  Passphrase = [ Type=psk, Requirement=mandatory, Alternatives=[ WPS ] ]
  WPS = [ Type=wpspin, Requirement=alternate ]
Passphrase?
Connected wifi_1234
connmanctl> quit
UPDATE:
The real issue with this is it doesn't seem to survive a reboot. So after setting this up I can't then return the device to it's install location and connect to it.
Mike Dorsett avatar image
Mike Dorsett answered ·
All I had to do for the pi3 was:
root@raspberrypi2:~# connmanctl
connmanctl>
This survived a reboot, but the re-connection of the Wifi remained a bit flaky - particularly at low signal strength. I think that the number of retries is maybe too small.
This fix was needed with 2.6 to 2.8 os.
waffleking avatar image waffleking commented ·
I re-flashed the 2.72 firmware, and started fresh. I did have to perform the # connmanctl > enable wifi. But after I did that, I was able to setup my wifi via VictronConnect and it has been working fine for me even after reboot.
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
