Is there a way to get notified about firmware updates for specific Victron products?
No. Not a customized list.
If your devices are connected to a gx then you can check over vrm or victron connect if there are new updates available.
Of they are smart devices then victron connect will let you know when you connect to the device itself over bluetooth.
If you are wanting change logs and more in-depth knowlege then you will need an account on victron professional.
Hi @TheChad
In VictronProfessional there's a Dropbox sync option. This is the header on the firmware page..
Remotely Update VE.Direct Firmware
VictronConnect manual / Firmware updates
Updating a Victron Smart Solar MPPT Charge Controller with Victron Connect
VictronConnect configuration guide for VE.Bus products - Firmware Updates
27 People are following this question.
