gregoryfierens avatar image
gregoryfierens asked
Why is VE.BUS voltage used instead of Battery Voltage for change of Bulk to Absorption ?
I could not understand why my system was switching to absorption before reaching the indicated value (55,2v) and then I stumbled upon the VE.BUS DC Voltage difference with Battery Voltage ...
There is a difference and there might be reasons for it ... but shouldn't the charging state be triggered by the battery voltage of the system instead of VE.BUS DC voltage ?
Does anyone know if there is a way to configure this and/or make sure VE.BUS Voltage is the same as the Battery Voltage ?
battery chargingVE.Bus
mrhappy avatar image mrhappy commented ·
Just checked my system based on this your question. I do have volt sense wires going to the battery busbar and my VE-Bus DC voltage corresponds to my BMV-712 voltage within 10 mV. Maybe volt sense wires is what you need?
JohnC avatar image
JohnC answered ·
Hi @GregoryFierens
You have a GX device, so yes, you can have it use another V sensor. Typically the V from a bmv or smartshunt is pretty good.
https://www.victronenergy.com/media/pg/Cerbo_GX/en/dvcc---distributed-voltage-and-current-control.html
