I have a Lynx 1000 distributor and I’m wondering if I can power it via rj-9 or 10 or 11 cable from a Victron 500a/50 mV BMV shunt I have.
this is the shunt:
this is the shunt:
Hi wildbill2112, Can you explain what you want to power from the rj plus, as this normally goes to the battery monitor, right ?
Rob
27 People are following this question.
Lynx Shunt VE.Can installation
hey all, cant get ve bus to appear/be detected
LYNX VE.CAN-Shunt: Location of the configurable onboard relay
Will the Fuse LEDs on Lynx Distributor illuminate without the 4-pin cable supplied with unit?
Lynx Shunt VE.CAN Battery Status PGN for Batt Instance 0 not transmitted.
