nelsonpk avatar image
nelsonpk asked
Screenshot questions
I assume that the Solar numbers are the output from the panel & the Battery numbers are the output from the 75/15 MMPT controller.
why is the current / amps higher than panel output?
My BMV 700 shows the actual amp input somewhere in the middle of these 2 numbers.
battery charging
klim8skeptic avatar image
klim8skeptic answered ·
Power into the mppt pretty much equals power out, minus some small losses.
Power = Volts x Amps.
22.51v x 4.7a (105w) into the mppt would equal about 14.58v x 7.1a (103.5w) out to the battery.
nelsonpk avatar image nelsonpk commented ·
So the regulator reduces the Volts which then increases the Amps.
The Battery numbers are what is actually going to the battery?
klim8skeptic avatar image klim8skeptic ♦ nelsonpk commented ·
Current into the battery excludes any loads running.
nelsonpk avatar image nelsonpk klim8skeptic ♦ commented ·
Thanks
