Have recently replaced a BMV712 with a Lynx shunt.
We run a Cerbo and the 712 was working perfectly. Since installing the Lynx we have lost DC consumption from graph data in VRM, any help appreciated
This issue is still ongoing, we have swapped the Lynx out for the 712 and data logging again is perfect, re instal Lynx same issue, the shunt is reading/displaying correctly, but the DC loads is not being included in the VRM historical graphs.Screenshot_20220121-075310_Samsung Internet.jpg
I have this exact problem on two sites as well. Would appreciate knowing any tricks to get resolution.
Same problem here. It has been discussed here: https://community.victronenergy.com/questions/118749/dc-consumption-data-missing-on-vrm.html
Not happy with that, considering it is working perfectly with the smart shunt in another system.
30 People are following this question.
Lynx Shunt VE.Can installation
hey all, cant get ve bus to appear/be detected
LYNX VE.CAN-Shunt: Location of the configurable onboard relay
Will the Fuse LEDs on Lynx Distributor illuminate without the 4-pin cable supplied with unit?
Lynx Shunt VE.CAN Battery Status PGN for Batt Instance 0 not transmitted.
