dave-t-1 avatar image
dave-t-1 asked
skylla IP65 DC fault current
I am looking for a reference for the available DC fault current and duration for the Skylla IP65. It isn't stated in the datasheet or installation manual. Possibly it is stated in another document? Note: fault current from the battteries is easily calculated and is a different aspect
documentation
wkirby avatar image
wkirby answered ·
The charger wouldn't produce much moe than its rated output if the failure mode was a loss of regulation which is most unlikely, besides there are most probably protections inside for this type of falure. In a very unfortunate circumstance, a short circuit within is a more likely failure mode in which case the batteries will supply the fault current.
