drdiesel avatar image
drdiesel asked
Quattro builtin battery monitor + BMV-712
I have an existing setup of a battery (large 48v/1500AH), BMV-712 and several MPPT 250/100s that I'm getting ready to add a Quattro to. The Quattro says it has a built in battery monitor, is this battery monitor essentially redundant if I've already got the 712, should I keep/rely on the 712 or toss it in favor of the Quattro's built in?
BR
MultiPlus Quattro Inverter ChargerBMV Battery Monitor
Kevin Windrem avatar image
Kevin Windrem answered ·
The Quatro and Multi do have built-in battery monitoring but only provide useful information for systems without other charging sources and DC loads because those currents would not be sensed by the internal battery monitor.
mrhappy avatar image
mrhappy answered ·
The BMV-712 is far superior as it measures the exact current with a shunt placed in the optimal position. I would say the Quattro's built in battery monitor is redundant, and can preferably be turned off.
