stevenfox1 avatar image
stevenfox1 asked
Not Auto Synchronizing
I have a 500 amp smart shunt connected to 2 Lion Energy UT 1300 LIFPO4 batteries in parallel. 105 Amp Hour each. I am having difficulty getting them to Auto Sync. The manufacturer recommended the following settings. Battery Cap. 210. Charge V 13.9V. Discharge floor 20%. Tail Current 4.00%. Charged Det. Time 3m. Peugeot Exp.1.05. Charge Eff.factor 99%. Current Threshold 0.10A. Time to go avg. Period 3m.
SmartShunt
R Robinson avatar image
R Robinson answered ·
All sounds right to me, I just installed mine with the same settings, seems to be working correctly. Where in the system is yours installed?
stevenfox1 avatar image stevenfox1 commented ·
I installed it according to the instructions. I doubled check and everything is connected where it should be. Everything working except I can't get it to auto sync.
"A synchronization is counted every time the state of charge drops below 90% before a synchronization occurs."
https://www.victronenergy.com/media/pg/SmartShunt/en/operation.html#UUID-fb41551c-8916-9f71-17bf-259a7fee2012
I have had the SOC down to 80% and recharged them with the power converter in my travel trailer. I upgraded the power converter to WFCO 8950L2 MBA designed to charge lithium batteries. The charge is two stage with a bulk charge 14.6v and absorption 13.6v. When I here the charger stop charging I switch the power converter off. Should I leave the power converter on longer.? Thank you for your help.
Kevin Windrem avatar image Kevin Windrem stevenfox1 commented ·
I would say, yes leave the charger on at least until the SmartShunt synchronizes. This could take a while.
I'm not sure why you'd want to turn off the charger at all.
