walter-kalani avatar image
walter-kalani asked
MultiPlus and multicontrol panel Led do not coordinate
Hello everyone, I have a Victron Multplus 12, 3000,120-50, 230 and a digital multi control panel recently installed. Everything work fine but the led for indicating Inverter on the multiControl Panel does not work although it does on the Multi Plus at the same time. The inverter is working without problems. . Any thoughts and help would be very much apprecia. Thank you !
Digital Multi Control
pba avatar image
pba answered ·
if the other LEDs on the DMC work correctly (i.e. match the behavior of the LEDs on the Multiplus) then the most likely cause is a hardware failure in the DMC.
