Does somebody have the distance between the mounting holes on the Victron 500A shunt?
Thanks,
Allan.
Thanks,
Allan.
Victron shunt# SHU500050100
Base mounting holes are 4inches or 101.6mm hole centres and 6mm ID.
Cable mountings are 2.25inch hole centres, (57mm) and M10x1.5mm thread.
the small screw holes are 58.8mm centre to centre.
Hope this is what you are after.
Cheers, Darren
5 People are following this question.
