bloudan avatar image
bloudan asked
Easysolar 24/1600 switch all off panel, battery..
For the purpose of maintenance, do you disconnect the PV panels and battery connection by switching of the easysolar 24/1600 from the front panel or is this just to turn of the inverter and ac charger.
No line fuses or external breakers are used to minimize unexpected faults.
EasySolar All-in-One
wkirby avatar image
wkirby answered ·
The switch is used to switch off the inverter charger. The switch does not affect the solar MPPT at all.
For maintainence purposes it's best to disconnect the PV array and the battery. Also disconnect any incoming AC sources to be safe.
bloudan avatar image bloudan commented ·
For the purpose of victron equipments do you disconnect battery+ then PV. There are conflecting theory.
klim8skeptic avatar image klim8skeptic ♦ bloudan commented ·
Follow the manuals instructions.
Disconnections are in the reverse order.
