When grid turns back on, does the ac output switch to grid or continue using power from batteries.
I know ac1 or boiler is a bypass from grid but what about the other ac outs.
Can be configured for your requirements, generally when grid is active you want to connect to the grid, but the easy solar can still use battery power so you are not drawing power from the grid.
32 People are following this question.
