marco-biroli avatar image
marco-biroli asked
Voltage drop Victron argo FET
Good morning,
I have installed on my boat a Victron ARGO FET 200. The device is connected on one side with the engine battery, on the other with 4 batteries for services.
I have the following problem: with the engine running I register 13.7 Volt on both banks of batteries. If the demand on the service batteries is high (even if for short period - i.e. the use of the bow thruster) the voltage on the engine battery drops below 13 Volt ( 12.7 Volt). This generate an alarm warning on the engine circuit ( Volvo Penta MDI system) set to run over 13 Volt. Is there any way to overcome the problem of voltage drop? Many thanks for any help.
Kind Regards
Marco
Argo FET Diode
