bloudan avatar image
bloudan asked
Max charge current easysolar
I have two tubular batteries 250ah connected in series
each rated at max charge current of 25a from datasheet.
PV input provide 22a
Solar charger provides 40a
What happens if I apply both charge sources to the batteries. Is the mppt 100/50 going to limit the amp or is the batteries internal resistance will limit the current or get damaged..........
EasySolar All-in-One
basil katakuzinos avatar image
basil katakuzinos answered ·
Someone can confirm but I would imagine the Easy solar works like any current Victron system with a GX device, if everything is set and connected correctly the GX device will ensure that max charge current is not exceeded.
