curb71 avatar image
curb71 asked
Can I use a charge controller on a solar generator to regulate voltage
I'm guessing a lot of you are familiar with the term solar generator? An all-in-one lithium battery pack with an inverter, converter, solar charge controller, and numerous inputs and outputs.
I have quite a few of them and they all have different specs when it comes to charging from solar. I'd like to max out my solar array for the largest one which has a 48 volt battery bank and a 150V/12A max DC input but then I'm unable to use that same solar array for smaller ones. Some of which are wired for 24 volts.
If I wired in an additional victron solar charge controller like the 150/35, would I then be able to use the same solar array for the smaller solar generators? The smaller ones have a maximum VOC of 25.
Help
