Easysolar mppt 100/50 blue led changes from float to bulk quickly after small load. It does not go to absorption. What does that indicate.
We would need more info Settings used battery type and size?
More details regarding your PV setup, what kind of tubular batteries, voltage, parallel, serial ?
Michel
Two 12v batteries led acid 250ah each in series
Four 400w solar panels each 2 in series then both pairs in parallel.
32 People are following this question.
