climbs avatar image
climbs asked
Cerbo GX relay for water Pump
Relay 1 set to “water pump”
Water pump set to “no sensor”
When operating the “pump on” on Home Screen the relay does not actuate. However, when operating the relay manually it will trigger the pump. Am I missing something or can I put the relay on the splash screen someway?
cerbo gx
Bob Akers avatar image
Bob Akers answered ·
@climbs just cam across this issue today when I rewired my pump so I could control the pump through the CCGX. Did you find a solution?
Thanks
Bob
