Ebrahim Railoun avatar image
Ebrahim Railoun asked
EM24 - Causing Cerbo Main Screen No Values
Cerbo - No values.jpegGood Day
I am out of Solutions.
When I Switch on The EM24 – The Cerbo Main Screen Has No Values and I have ESS Loaded.
When I switch off the EM24 – All Values in Main Screen Re-Appears and ESS is available.
Unit ID: -1
- When EM24 is Off.
- When EM24 is Switched ON
I Have Switched the Grid Meter EM24 OFF – until I can find a Solution/Fault.
Also – Strange - Battery on Charge – Values Neg.
Time 19h45 – 13 Aug 2021
EM24 Serial setting on 1 & only works on 1. Changed this many other no’s – then the Cerbo Does not Find It.
Please Advise
Regards
cerbo gx
