Can I use Blue Smart 12V charger with 3 outputs to charge 3 different battery types at once? Like to charge a traditional acid battery and LiFePO4 at the same time?
You can but you can only setup one charging algorithm in the charger.
37 People are following this question.
Blue Smart IP65 Charger - need details about Li-Ion mode
2xBlue smart IP22 charger 12/30 (3) parallel on LiFePo4 questions
Replacing/Coexisting Sargent campervan components with Victron
Blue Smart 12/17 settings to charge LiFePo4
Charging a 12V Lifepo4 battery. Who has the key to this mystical knowledge?
