Connecting the MK3 to USB cable to the USB port on my computer causes the computer to reboot. It will continue this reboot cycle until the MK3 to USB is removed. Any other USB cable plugged into the computer does not cause this problem.
Can you test the MK3 on another PC/laptop?
If the same happens on a second PC it could be a defective MK3.
If it works an the second PC the fit maybe have a driver problem.
Does the MK3 work with your Mac? You can run VictronConnect and connect to the MK3. You can use your Mac to run VEConfig too if you use CrossOver. See https://community.victronenergy.com/questions/3404/how-do-i-use-ve-configure-with-a-mac.html?childToView=86585#answer-86585
VictronConnect is now pretty capable. It can even configure a system of up to 3 VE.Bus inverter/chargers. (parallel or 2-3 phase systems). It does not support assistants, virtual switch, VE.Bus BMS, and a couple of other limitations
For these more complex situations, VE.Configure also runs fine under Parallels on my Mac. It's another option but costs more than CrossOver, but if you have it and a copy of Windows already...
28 People are following this question.
