HI
Is it possible to leave "AC out 2" on permanently, regardless of "AC in" is active or not (with grid/gen or not)?
I imagine a programmable relay assistant with acout2 relay on is battery voltage higher than you cut-off value will keep the ac out 2 on permanently. But why would you want this? What would the application be? Why don't you connect to AC1?
26 People are following this question.
