Lionel SEYDOUX avatar image
Lionel SEYDOUX asked
Equalizing
Hello from the southern french Alps!
In my house, my 12 OPZS batteries have been in use for 10 years. I think they should be equalized somehow. I tried:
  • the manual procedure (switch to charge only, back to on, back to charge only). No result.
  • Using veconfigure: the automatic periodic equalizing only catches with tube traction opzs. Mine are plates.
Shoul I dare set veconfigure to tube traction batteries or is there any other solution?
Thanks
Lionel
ESSbattery capacity
How does your batteries that were installed in 2019 have 10 years of use?
Lionel SEYDOUX avatar image Lionel SEYDOUX klim8skeptic ♦ commented ·
Batteries installed 2012. Only the Victron managemeny system inst
Lionel SEYDOUX answered ·
Batteries installed 2012. Only Victron management system installed 2019
Alexandra avatar image
Alexandra answered ·
@Lionel SEYDOUX
It is probably not a good idea to equalise now. If they have been from the beginning it will be ok though. If they have been in use for a few years and not equalised at all they will have sulphated, they may shed alot of material and short plates internally.
Did something similar not on OPZs though, but still lead based, had been in the system 5 years never been equalised and killed the batteries.
Plate Shedding. Courtesy APR.
What is ESS training video
ESS Quick Installation Guide
ESS design and installation manual
