Dashboard showing a very low PV wattage, and its a clear sunny day.
Is this because the MPPT controller is throttling the energy input into the batteries?
Running a 48V system, AGM battery bank, Mppt 150/100
"Is this because the MPPT controller is throttling the energy input into the batteries? "
Yes, your mppt has moved into the Float charge state.
After the charger has changed states the best you can do is to look up the history in VRM advanced tab. PV watts going into the mppt is not available, however watts from the mppt to battery is. (and other stuff)
25 People are following this question.
