Kevin Windrem avatar image
Kevin Windrem asked
Bug report: Brightness maximum being set incorrectly on Raspberry PI
/Settings/Gui/Brightness is being set to a max of 100 when Venus OS boots.
The maximum value of the Raspberry PI 7" touchscreen is 255 so the maximum brightness available is about 40%.
You can set the brightness to a higher value in the Display menu but it is set back to 100 after boot. dbus-spy will only allow values up to 100 as well.
Restarting the gui (killall gui) resets the max to 100.
Venus OSRaspberry Pi
jeroen avatar image jeroen ♦ commented ·
Hello @Kevin Windrem, can you check what /sys/class/backlight/backlight/max_brightness contains for this backlight driver.
Kevin Windrem avatar image Kevin Windrem jeroen ♦ commented ·
It's 255.
FYI, this value propagates to the veplatform values used in the Display menu. So I think the issue is just the /Settings value that's reset each time the GUI boots.
jeroen avatar image jeroen ♦ Kevin Windrem commented ·
Ah indeed, the backlight has a max of 100 at the moment. That shouldn't be hard to fix.
Kevin Windrem answered ·
My RpiDisplaySetup now resets the max brightness value every time the GUI starts up. This is a messy way to solve the problem but it appears to work.
