kennybuntinx avatar image
kennybuntinx asked
Cerbo CX : Wrong solar power readings
Hi ,
Some background info . Starting to build my victron system slowly from the ground up.
I have 3 solar inverters :
- 1x Kostal piko 5.5 - 3 phase
- 1x Ginglong 2.9 Kwp - 1 phase
- 1x Ginglong 2.1 Kwp - 1 phase
I bought a Cerbo CX installed and 2 x ET340 and 2x ET112. To connect them I bought 4x RS385 industrial galvanic seperated converters and a powered USB HuB. The devices show up perfectly.
The readings where ok until I connected the last ET112 (Solis 2.9 Kwp) to the CerboCx.
I see my consumption on the AC Loads increasing as my power increases that comes out op my Solis 2.9 kwp inverter . As soon as I turn the solis inverter 2.9 kwp off , the readings on the AC loads are perfect .
Also for some reason we sometimes have a generator in there ? I don't have one and the readings are static . If I refresh the page sometimes and then it's gone ? UI bug ?
Please help . Any advice appreciated .
Kenny
cerbo gx
