Am trying to connect 4 pcs of 5K3 Weco lithium iron batteries to the victron color control through the CAN port but they are not getting detected anyone who can help me probably guide me on how to go about it, will be greatful
Try to set the data rate of the Can.bus port to 500kbit/s in the settings of the CCGX. The setting should be somewhere in the lower menu.
You maybe also have to check the pinout of your batteries Can.bus and look if you need a special cable (type A or B), a normal patch cable or something other.
44 People are following this question.
