Allan Yates avatar image
Allan Yates asked
Skylla IP44/65 Charger Storage Mode Firmware Bug
I have been observing a firmware bug in the Skylla IP44/65 chargers. This only started occurring with either the latest (1.10) or very recent firmware. Upon power-up, the charger often jumps directly into Storage mode, or cycles briefly through Bulk and into Storage. The result obviously being that the battery bank never gets charged. This is being observed on a regular basis.
As an attempted work around,I have configured setting 30 "Watch Function (start-up in storage if battery voltage > 13V)" to OFF. Though the battery voltage was not close to 13V until the charger was powered up. Initial testing shows this to have worked around the issue; we will be able to confirm over the next week as the charger goes through multiple power cycles.
We are running a pair of synchonised chargers. One is a 60A IP44 and the other a 70A IP65.
@Guy Stewart (Victron Community Manager)
@mvader (Victron Energy)
Over the past several weeks, there have been no more issues with the chargers going immediately to storage mode. So I can confirm that the workaround listed above does work.
Allan.
firmware updateSkylla
malolo avatar image
malolo answered ·
I’ve had similar issues but with the IP-65 going into float without cycling through the other steps. Turning ”watch mode“ off resolved the issue.
Allen Roberts avatar image
Allen Roberts answered ·
Thank you.. this post solved my Skylla issue with stuck in "storage" state. I agree this seems to be a firmware bug. If Li mode (battery type 7) is set, watch should be off by default. Li battery would rarely be under 13V so the charger would only do a maintaining, not charging with watch mode on.
