coryhanes avatar image
coryhanes asked
2 Temp Sensors… Which one do I use?
The MultiPlus 3000 came with a battery temperature sensor (mounts to neg battery post) and the MK3 USB dongle has a built in temp sensor (peel and stick to battery). Which one is primary, or does the system use data from both? If it pulls temp data from both… I have a split bank (two battery banks in parallel) setup. Can I use both sensor on the same MultiPlus one on each bank?
Temperature Sensor
