fritzdfk avatar image
fritzdfk asked
Battery Protect and Capacitors
I plan to use a Smart Battery Protect on a circuit that will be used to charge batteries for an electric outboard. I am concerned about the warning in the manual about connecting inverters or anything with capacitors. The Epropulsion outboard uses detachable 48 volt batteries. A couple different chargers can be used that operate from 12 volt systems. Are these chargers similar to an inverter and do they contain capacitors?
Battery Protect
