We have a new installation of a quatro 5kw, mppt, bv bus, cyrix, BMV700, Lithium batteries and a colour controller. The system is up and working ok on AC input, inverting and battery monitoring and SOC display but the DC power box is a little crazy. Even if there is no DC load called for it shows a fluctuating value in minus and plus values. If you put on the inverter to pull a load from the batteries the controller shows an output but not consistant. Also it does not show any input from the alternator when the engine is running(its a marine installation)
Any ideas on why the DC values are all over the place. Also the line connection on the screen seems to show the current flowing the wrong way considering the minus or plus figure in the DC box.
