Good morning, I have problems with my bmv 700 monitor, how can you see it shows me 77% load but the system voltage is below 77%. Any way to solve it?
It is not abnormal for voltage to drop under load, but looking at your loads it should not be dropping like that. So if you are certain your bank is not weak or unbalanced then you may be experiencing what is known as SOC drift.
So you will need to revisit either your peukerts exponent, or see if it is syncing to 100% to early. Often these are the two culprits.
https://www.youtube.com/watch?v=mEN15Z_S4kE
https://www.youtube.com/watch?v=4ReljfO3k6M
You would need to share your battery bank details and your current BMV settings if you would like more specific help.
Victron BMV battery monitors product page
32 People are following this question.
