Peter Buijs - NL avatar image
Peter Buijs - NL asked
MK3 Case Lost
Unfortunately I lost the top part of the case from my MK3 interface.
The interface is still fully functional but like this it is vulnerable.
It is somewhere in the bilge of a large ship under the motor, not able to find it there.
So if someone has a defective MK3 lying around I would be helped.
Any other cheap solution is welcome.
I suppose Victron is not able to deliver an empty case...
MK3
juan3211 avatar image
juan3211 answered ·
Hi, may be any 3d case printed?
I need your help, I haven't any victron equipment but i am thinking about it, could you please attach here more photos of the mk3 "chips"?
I want to know if i could get UART interface from pcb board. Probable before usb there is any uart-usb converter IC.
I want to read the IC's marks to know if any of them is a uart-usb converter.
There are 3 chips near usb connection: one with 8 pins, other with 16 pin (I see) and another one with lots of pins, could you attach here their photos? Thanks (or even, write here their marks/names)
Please, help me, thanks
wkirby avatar image wkirby ♦♦ commented ·
There is a FTDI USB-Serial converter. There is a digital isolator also.
Your biggest problem is the big chip is a PIC microcontroller. The MK3 firmware for this PIC is not available.
