stefang avatar image
stefang asked
How to initiate Dbus-1 communication between Color control and Raspberry Pi ?
firstly the idea is to use 3rd party raspberry to communicate to the color control to able use node red to change inverter output and grid set-point according to weather factors.
i have been able to access the color control via the raspberry Pi using ssh root commands, on the local wifi network. also able to "spy" the Dbus-1 content via terminal on the Pi.viewing all the values and set-points
i have tried to edit /etc/dbus-1/system.conf but failed My Question is how to setup the communication so i can use the node-red-contrib-victron nodes in node red?
CCGX Color ControlRaspberry Pi
bathnm avatar image
bathnm answered ·
