tg1 avatar image
tg1 asked
Can I use the H & L remote inputs of the Battery Protect at the same time?
Hi all,
Can I use the H & L remote inputs on a Battery Protect 65 at the same time from two different sources?
Ideally I'd like to use the High level input for a rocker switch to turn the BP65 on/off. & I'd like to use the Low level input for a BMV-712, SOC relay to switch the BP65 on/off.
I accept I could use both the switch & relay in series and switch either one of the H/L inputs. However being able to use both at the same time, in my case would reduce complexity & wiring.
Thanks for you input.
Battery Protect
Mike Dorsett avatar image
Mike Dorsett answered ·
From the data sheet, it looks like there is only one remote control loop - screenshot-from-2021-07-20-15-28-04.png
So it looks like you will have to wire your switch and relay in series to make that work...
tg1 avatar image tg1 commented ·
Thanks Mike,
bp65.pngThe alternative to the remote loop is to use either the H/L inputs. H for battery positive, L for battery negative.
Again, really just interested to know if anything will be damaged if I put 12vdc on the H input and 0vdc on the low at the same time.
stevensnel avatar image
stevensnel answered ·
I was wondering the same thing. In the manual of the orion dc-to-dc it shows both a connection to a switch (ignition in this case) and the BMS (ATC in this case). Why would the battery protect be different?img-3969.jpeg
