Is it possible to configure Venus to accept a VE-Direct connection on the Raspberry Pi built in UART? This is normally configured as /dev/ttyS0 under Raspian, what needs to be configured in Venus to get this to work?
Yes it does work on the raspi3B+ with the older ver 2.66 software.
I did not try this with the 2.66, only with the 2.72 software....Thanks.
Hi
Yes it only works on the older version <2.66
I used the SPI links as per schematics.
Victron Raspi Stetson.pdfVictron Raspi Hat.pdf
Regards
Rob D
NZ
49 People are following this question.
