Can I activate a fan (relay) from either the Quattro or Venus GX based on current temp ?
Thanks,
Pieter
Yes you can. use use the Assistant options to control on of the AUx relays that would then drive a relay that controls the fan.
OR if you dont use AC2 out on the inverter you could turn that on /off as well and connect the fan directly to ac2 out, and use the assistant to control when AC2 turns the fan on
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
8 People are following this question.
