igor avatar image
igor asked
diode bridge necessary with ip22 charger?
I have a starter battery and a service battery on my boat and need to replace the charger. The old charger has a single output. Both batteries are connected to the alternator via a diode bridge. If I connect both batteries separately to the charger, will I still need the diode bridge? How then does the alternator gets connected without messing things up? Here's an image of the current setup:
chargerip22
