I am using an 8S Nissan Leaf battery system and use 32.88v at programmed full.
I'd like to know if the 24/3000/230 Multiplus II GX is capable of a programmed 32.88V DC output to charge this battery bank.
The highest charge voltage you can set with a 24V MultiPlus is 32V.
Enjoy the day.
Is it possible to use 3x Orion 24/48 8.5A converters after a 12/24 buck boost 100/50 then into an MPPT to go from the 12v starter battery up to the 33v house battery at similar amperage?
44 People are following this question.
