palu3492 avatar image
palu3492 asked
BlueSolar bulk HEX commands over serial getting inconsistent responses
I'm sending many HEX Get commands at one time to my BlueSolar 75|10 over serial via Python but the responses are almost never the full response.
Example request:
:7FEED0063
:71222001A
:71122001B
:790ED00D1
:7FDED0064
:7E5ED007C
Response:
:7FEED000162
:A0002000148
:A0102000048
:71122002003F8
:790ED01D0
:A0202000200000045
:AD5ED00DA04AB
:AADED000100B0
Some of the requests are getting responses but not all of them.
When I send about 70 commands at once I usually only get about 50 responses.
Python code:
import serial
string = """
:7FEED0063
:71222001A
:71122001B
:790ED00D1
:7FDED0064
:7E5ED007C
s = serial.Serial('/dev/hw/bluesolar', baudrate = 19200,parity=serial.PARITY_NONE,stopbits=serial.STOPBITS_ONE, bytesize=serial.EIGHTBITS)
s.flushInput()
s.flushOutput()
s.write(string)
r = s.read_until("\r")
print(r)
Any idea why this happens?
Thanks.
MPPT Controllers
Thiemo van Engelen (Victron Energy staff) avatar image
Thiemo van Engelen (Victron Energy staff) answered ·
Hi @palu3492
This happens because the MPPT does not have a very big input buffer for its serial port and it needs time to handle a command. Because of this, some bytes are lost on the MPPT side, causing it to receive incomplete commands and ignoring that data.
The solution is to send 1 command and wait for a response before sending the next command.
Kind regards,
Thiemo van Engelen
4 comments
palu3492 avatar image palu3492 commented ·
Thanks for the answer. I suspected it was something like that but I wanted to avoid sending 70 individual commands and waiting for each to go through. I'll modify my code and test that out.
I did find that if I separated each command, in the bulk message, with many \n, I was able to get more responses from the MPPT.
I'm successfully retrieving all variables when sending each command individually. However, it seems I need a delay in between each command, or else the command will fail. How much delay is required? If I was retrieving 70 variables, do I need to send each request individually or is there a more efficent way to do this?
Thiemo van Engelen (Victron Energy staff) avatar image Thiemo van Engelen (Victron Energy staff) ♦ palu3492 commented ·
Hi
It should not be necessary to add delays. When you wait until you have a proper answer for the request you sent (so when sending a :7 command, also wait for the corresponding :7 response) it should work.
When this is not the case, please add a logging that shows the problem so we can look at it.
Kind regards,
Thiemo van Engelen
palu3492 avatar image palu3492 Thiemo van Engelen (Victron Energy staff) ♦ commented ·
I discovered my serial reading was the problem. A delay is no longer needed in my code. Fetching the 70 variables I'm looking for now takes about 4 seconds which is perfect for me.
Reading using the method read_until("\r") was the problem. I'm now essentially doing read_until(":7") + read_until("\n") then parsing.
Thanks!
