craighealy avatar image
craighealy asked
Normal and High preset charging modifications?
Can I change the normal and high preset charging defaults? Alternatively, can I re assign user defined settings to the mode switch. I would like to customize the settings and use the mode swith to toggle between two (much simpler than bluetooth). One "normal" for slow charging under shore power and one "high" for fast charging with a generator. I'm using Renergy AGM batteries which have slightly different charging specs than the normal and high defaults.
chargerAGM Battery
Mike Dorsett avatar image
Mike Dorsett answered ·
Hi Craig,
Some more details about your system would help to answer the question. What are you using and how is it set up?
craighealy avatar image craighealy commented ·
Hi Mike, thanks for the quick reply. I'm using a Blue Smart IP22 120v 30a single output charger with a 200ah battery bank on a travel trailer. What other info do you need?
