Hi, my older Atlas combi 24V 1800w.manages to regularly pop the grids 6A220Vac fuse... When charging in boost mode... Is there a way to cap the "boost mode" for the charger?
This is a very old unit and its also not a full sinewave inverter/charger ( ie square wave)
No there is no way to cap the incoming current on these units as far as I know
I have attached the manual for the unit, as this maybe of help for you
I am also at a loss as to know where this fuse you speak of is as I cant see it in the manual and the manual indicates that the incoming fuse should be at least 25 amps Ac10001e.PDF
MultiPlus Product page / Quattro Product page
MultiPlus 230V Manual / Quattro 230V Manual
44 People are following this question.
