Carlos Carvalho avatar image
Carlos Carvalho asked
MPPT Solar Charger with ESS external control
According to manual the MPPT follows the VE configure charge curve.
https://www.victronenergy.com/media/pg/Energy_Storage_System/en/configuration.html#UUID-4b3ef00a-5b01-af45-c514-fed6262ec7e3
In VE configure the max charge is set to 48V.
However this is not happening.
How to have this fixed as the MPPT keeps increasing voltage when using ESS. If I use hub instead of ESS the MPPT behaves as it should.
ESSmppt charging
Carlos Carvalho answered ·
Has this occurred to others?
