johanr avatar image
johanr asked
What mppt to get?
Can you please assist on what size mppt controller I should get:
Solar panel specs
2x 120 w in parallel
Pm 120w per panel
Voc 24.2v
Isc 6.46a
Imp 6.07a
Temp coefficient Voc -0.33%/C
Temp coefficient Isc 0.06%/C
Normal operating cell temp -45 to 80C
Battery specs
13v 108ah lifepo4 lithium 1400wh
Float charge 13.6v
MPPT Controllers
Elimac avatar image
Elimac answered ·
A 75/15 will do. Choose lithium profile.
But keep in mind that you may need more pannels, depending or your load.
Ingo avatar image Ingo commented ·
I wonder about that, rather use the Victron MPPT Calc spreadsheet to verify the best selection. The charge current will be clamped at 15A when using a 75/15. I would use a 100/30 to be on the safe side as you can get 23A out of it during peak conditions.
Elimac avatar image Elimac Ingo commented ·
If one is worried about that, then the /20 would be a perfect fit for those pannels. And I would connect them in series.
