What is the current state of support for something like the SeeLevel II 709-RVC CAN bus tank monitor?
No change in RVC status but Garnet does sell a NMEA2000 version of their 3-tank sensor system. It's not in the catalog so you need to contact Garnet directly to see if they'll sell you one.
The N2K version works with Venus v2.71 and newer. But with long internally generated tank names. My GuiMods truncates the tank names to 3 words making the display look better.
https://github.com/kwindrem/GuiMods
TankRepeater makes the N2K version work for Venus v2.66 and older:
For what it's worth, you would only need to replace the display module. The senders you have can be reused.
If you need RV-C data for other displays in your RV then you'd need to ask Garnet about running an RV-C display along side an N2K display, one as a primary and one as a secondary.
@Kevin Windrem [@Victron] would it be possible in venusos or when guimods truncated the name an option to use a nickname since I have 1 fresh 2 grey and 2 black. I see all tanks in venusos but it's not intuitive which tanks are which
This is why I've been begging Victron to provide a custom name field for all such external devices. This is not an issue for local tanks but for those that come in externally, Victron's position is the external device should provide the custom name. (Tank capacity is also in this same category but SeeLevel RV-C does not provide it.)
28 People are following this question.
