u076216 avatar image
Is SmartSolar MPPT 75/10 a serial or a shunt Controller ?
I have now gone through all the documents and data sheets from the download area and have not yet found an answer to my question.
Is the xxx a serial or a shunt controller? So is the voltage of the solar panels short-circuited (shunt) or only switched off (serial) when the battery is 100%?
Thank you and have a nice day.
Matthias
MPPT Controllers
u076216 answered ·
xxx = SmartSolar MPPT 75/10
wkirby avatar image
wkirby answered ·
The MPPT generally presents a higher impedance to the solar array as demand decreases. Only when a power point scan is performed will a short high low impedance sweep be observed.
klim8skeptic avatar image
klim8skeptic answered ·
"So is the voltage of the solar panels short-circuited (shunt) or only switched off (serial) when the battery is 100%? "
In the terms you mentioned above, the mppt controller reduces the current drawn from the PV array, to control it's output current/battery voltage.
