jevil avatar image
jevil asked
Using SmartSolar 75/15 with float voltage only
Hi.
Is it possible to set bulk voltage = float voltage @ 13.6V ? I use my caravan's AGM-battery more as a usv or for peak loads than as a cycle battery. So for extending livetime of the battery I want to prevent the charger to use that battery cooking high bulk voltage.
What will the charger do if I set both voltage equal?
Best Regrads,
Jens
MPPT ControllersAGM Battery
Paul B avatar image
Paul B answered ·
just set the absorption voltage to the same as the float voltage
MPPT Product Page
MPPT Error codes
