nyyankees588 avatar image
nyyankees588 asked
Victron multiplus 3000 maximum operating temperature?
Hi there - does anybody know the operating ambient temperature range for the Victron multiplus 3000w inverter? Specifically, does the inverter have a built-in high temperature shutoff? What temperature is it triggered at?
I recently installed one of these inverters for a client in a space with less-than optimal ventilation. I installed a temperature-controlled fan in the space to help with ventilation, but just want to verify at what high temperature the inverter will cut off at. Thanks in advance.
MultiPlus Quattro Inverter ChargerTemperature Sensor
arghhh40k avatar image
arghhh40k answered ·
The spec sheets says -40F to 150F. You will probably get some power derate if you are at the high end of the table though.
Alan avatar image
Alan answered ·
Ours cuts in @ 40c if this is any help
